Hi,
Has anyone ever repositioned the railing stanchion bases on their side and bow handrails?
I have a 1984 Sailfish 255 with some interior leaks when it rains. I will expose and check my rub rail screws but also, my stanchion bases are loose and I know that they are bolted down and the nuts are near impossible to access. Has anyone ever cut the bolts, sealed the existing base location and drilled/screwed the bases 10 cm forward or aft?
Would there be enough material for big screws to bite into, to keep the railing safe?
Thank you.
Thank you.
