On these little plastic boats there is a way sealing holes for a very long time if care is taken in the prep.
I'm just giving a few examples. You can find this stuff everywhere. Get some Carbon Fiber tube $$$, G10 Tube and there is a whole family of that glass under pressure family. McMaster Carr will have info on it plus many more sites.
I find the tubes everywhere from Thrift Shops to Children's Toys. Go to your China Tool Outlet, get a big letter, number and fraction drill index, cheap one not my 500 dollar Champion Set. If you are a real High Roller get that fine China adjustable Reamer set. 50 bucks for both.
Get good FRESH Epoxy, fine cloth, (I have even used handkerchiefs) some fine mat to chop and stuff..
So our little Plastic boats are under Constant stress working at every bolt, never ending, squirt in a little saltwater, never ending while I'm looking for one of those Manatee's that Pho Pho 5 gallons at a time. I would think of a few of you have been on a Ferry, in the navy or like us working on these things for a lifetime.
If you have not, most will be shocked that a boat can shutter that much and stay together and that is on a good day. We where younger and had a job to do, using a Mike 8, Quads, landing craft. Both of us are licensed and we where running Hot Bunks with ice chests and berthing on the galley table. It was work and we had to get done. You run 6 on 6 off, 24/7, and they are not bluewater boats and running in the surf line. The pounding, shuttering, the popping of metal will take your breath away at times. That is happing to our plastic boats on a smaller scale.
I replace all self tappers that I can. You want good clean prepped holes on the boat and what is being mounted. There is a lot of ways to drill it, use a lathe or a drill and sandpaper. When you prep holes take a small counter sink and put a small sink on all holes. Another $10 China Gizzmo. So these little tapers will hold and press in your 5200 on your bolt, washers and nuts. Ream your hole for a good fit.
Yes all this takes time. but you will have a boat like mine that you can bring a moisture meter to and be shocked, original tanks, never has had bottom paint and towed everywhere 30' Marlin.
A die grinder(S) air or electric, cutting wheel and sanding discs.
Get masking tape and dispenser, desk top type.
throw away sheetrock knives
Razors
MEK
Keep the Epoxy Fresh.
Masking paper dispenser
I use a little folding work bench. to TRY to keep it clean.
Hobby brushes
Robber Gloves
Just of the top of my head. Very cheap to do and your resale value go thru the roof. Everything is logged.
I you have suffered thru my 5 gallons of of Pho, Please look for my Florida post looking for info. I will explain a lot. We have had a Fantastic Life and have done way more than most. I have been asked a couple of times to write a book.
What I'm trying to say is JUST DO IT ! We have 1 ONE shot at this life.
