- May 23, 2019
- Age
- 57
- Fisherman 209
I seen many discussions on this but not directly to my questions. Gas tank was replaced recently so I wanted to confirm proper configuration. I have a green ground running duel connected (two wires split) to tank ground bar and fuel sender running to negative bus in console. Likewise have green ground running from fuel fill to same negative bus. Is this correct or 1. Does it need to connect directly to battery for some reason 2. Do both runs need to be connected in-line (same bus terminal) 3. Perhaps silly but does this wire need to have a fuse? Thanks.
