- Feb 4, 2021
- Adventure
Where is the intake for raw water on a 208? How do I rinse our salt water on land on the trailer?
That valve is a good safety upgrade also. Should your bilge ever get seriously flooded to the point your bilge pump can't keep up or the bilge pump fails then turning that valve to suck through the winterizing hose makes it possible to pump bilge water overboard with the washdown hose with the nozzle removed and the baitwell pump with the drain plug removed.I installed a 3 way with valve after the seacock and prior to going to the pumps. With a hose connected to this, I just stick it in a gallon jug and suck in the fresh water or in winter time, antifreeze to protect everything. It works like a charm.
Sounds like a lot of MacGuyver-ing in the middle of an emergency chaos situation.That valve is a good safety upgrade also. Should your bilge ever get seriously flooded to the point your bilge pump can't keep up or the bilge pump fails then turning that valve to suck through the winterizing hose makes it possible to pump bilge water overboard with the washdown hose with the nozzle removed and the baitwell pump with the drain plug removed.
