Sailfish 272 Hydraulic pump
dennis a
Valley Stream NY
I have a 1996 with twin 200 yamahas. they are starting to drop due to a lack of pressure Would any one have any information on how to change the valve and is this related to the indication on the gauge.
You say bothr motors are loosing tilt on their own?
If so, any leaks of fluid into the water around motors (rainbow sheen on water)?
272 sailfish hydraulic pump
Thank you for your reply there is no oil in the water the Port motor drops a little more than the starboard motor there is no oil tank only the pump and I can't find the name on the pump only a gold emblem.
The T&T unit has an integral electric motor/pump and fluid reservoir, do you have enough fluid in there?
If the reservoir is external and attached to the pump then I don't have one. I only see the pump. I also tryed to find a fill hole to check the oil.
Go to the Yamaha.com website and drill down to marine outboard motors, and you will find avaliable the owners manual for your year and model which you can view online, has the info you need to know on the tilt and trim.
