Yup that is easctly what I plan to do, I'll run mine down my walkway then tuck it neatly up under my coaming and out of the way, likely above the rod racks so it is away from gaff tips and flopping tuna!! I am considering as a project next winter, installing a receptical forward and just plugging the generator in there, then running wires internally and then under the cockpit and putting another receptical above my shore power connection, then just running a very short connection between the two to connect them, that way there are no power chords on deck at all, and I will need to have the adapter at the shore connection anyways. Not sure if it is worth the work yet, will have to see after a trip or two, if it seems to not be a problem I'll save myself the work. This also eliminates the need for an inverter, I'll be able to run my microwave on the water when offshore since the genset gets plugged into the shore power connection and then charges the batteries from there providing all the juice you need. Once that is installed, I'm going to add more or bigger spreader lights...more light=more bait, and hopefully that means more tuna!! Plus, we lost a sword at the gaff due to a lack of lighting, the stock spreaders just aren't enough for me.
