Salt water washdown add-on
Old Saybrook, CT
Hello,
I have a 1991 Fisherman and saw that one of the original factory options is a salt water washdown. I do a great deal of fishing and would benefit greatly from such a feature. How difficult would it be to add this on? Is this even possible? Cost, etc. ?
Thanks in advance!
ahill
Manatee Pocket, FL
Grady uses a Shurflo Baitmaster Pro for washdown.
You'll need a thru hull seacock, hose, hose bibb & misc electrical connections including switch, fuse and TINNED wire of appropriate size. Heat shrink all electrical connections.
BobP
If you are a competant DIYer, the only part of the job you may cringe is drilling several holes through the bottom of the hull, the rest is straightforward.
BobP
It can also double duty a a live well feed for as little as 18 bucks for Y valve plus more hose.
