Scupper Plugs on Deck
MDRookie01
Does anyone plug their rear scupper tubes on the deck when they are going out? Keeping the water from coming in when at anchor and there is a good amount of weight on the rear of the boat?
Scuppers
Maybe you need to replace the rubber flaps on the thru hulls. They should be doing the job.
Scupper plugs
I use pool fitting rubber plugs with a nylon wing nut to tighten the plug. This season I am trying to install a product by TH Marine that has a ping pong ball in it that stops water from entereing from the back of the transom. I find it very annoying to get water all over the aft end of the deck! I plan on plugging 2 scuppers and using these new TH Marine ball scuppers on the other 2. BTW, West Marine has the scupper with the ping pong ball.
Rod
1985 Fisherman 204
I bought some tapered solid rubber plugs at the hardware store, drilled them length wise, and put an eyebolt through, then a washer and lock nut on the other end. Tied a piece of parachute cord to the eye bolt and made a loop in the end of it. When I have the kicker on, I push these into the back side of the scubbers. $3.00 solution.
