There are two sets of scuppers on my 252 sailfish one set is well below the water line and drains the deck, i can see water in the deck holes and also the upper scuppers are letting water in to the transom well which is leaking through the bilge access and causing the boat to take on a minimal amount of water. I know the scuppers shouldn't allow water to enter just exit. therefore I know they all have to be replaced. My question is about the upper ones, is it common for them to be below the water line when the boat is realtively full of fuel (approx) 150 gallons? Also my manual and mechanic says that the warning buzzers are supposed to test themselves when you turn the keys on but mine dont, any thoughts?
252 Sailfish W Twin 200 Johnson Ocanrunners
