SD card
wcollins
Canyon 336
2008 GW 336 canyon with furuno vx2 displays, recently purchased SD card for inland lakes, nothing happens, won’t download card?
I don't know about the Furuno but on my other units, Lowrance and Garmin, there is an option in the head unit to select the data source.
Just to check; Did you confirm that the map software is compatible with your device?
Hopefully, you bought the chip from a reputable vendor.
Sardinia306Canyon
Island of Sardinia
Don't know bout Furuno neither, but my Garmin's see a new cart and ask if they should download the chart or start a software update.
Did you ever made a card update, or is it the first time?
You may have to look in the menu to tell the VX2 to look on the SD Card for a new chart.
Chris
Take the card to West Marine and see if they will check it in a unit for you. Worth a shot...
Gulffisher
No still wet behind the ears West Marine associate will know anything about NAVnet VX2. But... Furuno service will and they will actually still help you with this long obsoleted system. So look up their tech service phone number and call for help.
For now, the VX2 units were factory set for CMAP or Navionics, but not both. Which do you have?
VX2 upgrades have been released over the years and some were required to take advantage of the WIDE map formats. Check your VX2 firmware version and plan to upgrade if needed. I think the last update is 195002404.03 (might be different if CMAP or NAVIONICS, can't recall). Furuno will provide you links to software and instructions for upgrade.
VX2 SD cards are limited to 2 GB max if I recall.
Even if you update firmware and have the correct map type, you may still not be able to load the newest maps. I think my maps are from 2010 or so at the latest.
