Seafarer 228 Weight
bobdevlin
I am planning on buying a Grady White Seafarer 228 with a four stroke 225 HP Yamaha engine. I need a trailer and question the weight carrying capacity of it. Will a 5000 lb trailer do the job?
rml2112
Savannah GA
I have a 2000 seafarer 228 with a 225 2 stroke, I think Mine is a 5000 lb Capacity trailer.
bob
HMBJack
Half Moon Bay, CA.
When I owned my 228, with a F225 and T8 kicker, I calculated my boat to weight about 5,300 lbs. full of fuel (I had the Aux. tank as well).
I would think you'd want a two axle trailer, with disk brakes and a 7,500lb. capacity to allow for extra safety. Best to talk to an objective trailer shop about it but 228's are heavy for their size (a good thing BTW).
bdubz06
Seattle, WA
You will want to have about 10-15% fudge factor in the trailer. It is always better to have a trailer that is overbuilt than underbuilt for the load. When I was shopping for my 208 trailer I went with the 5400# instead of the 4600# because it was only another $600 and it would give me peace of mind.
Also, another thing to think about is if you take it on trips. Its good to have a little extra capacity to store items in the boat for trailering if you need to. I sometimes put our sleeping bags, tents, and other camping stuff in the boat to leave enough room for the heavy stuff in the bed of the truck.
Just my two cents :)
CJBROWN
Orange County, CA
Trailers are like tow vehicles - should be under 80% capacity. They really don't tend to be under-rated, either of them.
Do a search on trailers, or browse - there are several threads going on the subject currently.
G8RDave
Tampa, Florida
My 228 and aluminum trialer weighed around 6500lba at the wiegh station. The trailer weighs around 1000lbs. Your 5000lbs capacity trailer (even assuming that refers to what is on it and not including the trailer) might be a bit light.
JUST-IN-TIME
ON THE WATER
bigger the better
add fishing gear and gas and let say you went camping over the weekend and you put all the camping gear in the boat
6500K is pushing it
160 gallons of gas, at 8 lbs, is almost 1K, add almost 4K for boat and your at 5K
then the motor, say 6-7lbs, your at 5500
then add all you fishing weights, ice and gear, another 1k
go 7k
