- May 30, 2023
- Age
- 63
- Seafarer
I'm mounting a radar arch on my 1994 Seafarer 228g and from what I read I want the center of the radar to be level with the horizon when the the boat is at headway speed which often means tilting the radar down ~4 degrees. I plan to use the radar to navigate in the dark, fog, and to look for birds while cruising out to fishing spots which is usually at 24 MPH. Unfortunately, I have no sense for what angle the boat is at while underway. Does anyone have a sense for the angle of the boat at headway speed or advice for what angle to mount the radar arch?
I could mount the radar arch level or slightly angled down at 4° and then shim the radar to get the angle I want but would like the arch mounted close to the correct angle if possible. I'm sure it will take additional testing once the boat is in the water but I won't be able to get the boat in the water for a few more weeks and want to get the arch installed in the meantime.
