- May 17, 2023
- Age
- 58
- Express 265
yup, got bit by the Seastar gremlin this past weekend. found replacement kit online. However, my question is this; has anyone experienced leaking fluid from the hose connection nut fitting? I can wipe the fluid from the ram and suspect replacing the endcaps with new fittings from the replacement kit, but have not found info on any leaking from the nut (may be leaking). Did not see replacement nuts in the kit, only tool, end caps, and seals.
