Seats needed
abraz1957
I own a 2004 canyon 306 and I‘m missing the folding seat in the back (transom). Any recommendations where I can find one?
thanks
Grady White still makes the 306 Canyon to this day, of which if the seat looks the same or is similar to the new ones, it's possible that it might be interchangeable. A quick call to your local GW dealer might resolve the issue.
Best to contact GW Cust Service or your dealer. The seat is designed by GW and I believe is manufactured by Llebroc currently. GW owns the design and has moved too various manufacturers over the years. The manufactures cannot sell directly to customers. I suspect it will be expensive.
I agree with contacting GW.
Note: GW added a side door to the 306, which means the seat is smaller in 306s with the side door. Make sure you order the correct size/version.
Thank you all. I will contact the local GW. You’re correct that it will probably be expensive!
