- May 6, 2015
- Misquamicut, RI & Melrose, CT.
- Freedom 255
On Memorial Day, we took the GW out on our first shakedown cruise. We trailered it to a local ramp in Westerly, RI. (The boat came with a 8200# Load-Rite roller trailer.) With our son at the helm while I backed it in, off-loading was easy.
First stop was the gas dock since the Command link Plus gauge only read 35 gals. in the tank. Put in 100 gallons (filled it) but noticed the gauge did not reflect the additional fuel so we re-set it and it then read 135 gallons available. Is the only way to get an accurate fuel level reading with the CLP system is to top off the tank and re-set? What if I only put in 50 gallons?
After fueling up off to Mystic we went. The boat ran flawlessly. I was impressed with the ride even though we did not encounter any rough water. Tied up in Mystic for a bit and visited some friends. After a late lunch, we headed back to the ramp. Everything went smoothly until it was time to put the GW back on that horrid roller trailer. I did a bit of reading before venturing out. Most of what I have read from experienced roller trailer guys is to only dunk the rear set of rollers into the drink and winch the boat up and it will align straight. Well, this boat was having none of that. Simply too heavy to winch. After fiddling for about an hour at different trailer depths, we managed to get the boat to lay down straight while dealing with the wind and river current. Outside of converting to a bunk trailer there must be a better way. :bang After the boat was trailered, I noticed we lost the skeg anode. No visible prop damage though.
