Grady Owners,
Due to an emergency situation that resulted in a person operating my windlass who was unfamiliar with its limitations, my windlass has been damaged. It still functions both up and down, but will not hold tension on the rode once the anchor is snug on the bowsprit.
I have searched the archives and found some guidance which reflects the data in the owner's manual for the 400 or 500 series windlass, but the 600 is different. I have checked the clutch nut on the outside of the gypsy. I have also opened up the windlass and there were no visible broken teeth or slipping gears. The only part I was unable to see was the connection between the main drive gear and the electric motor itself.
I don't know of any boatyards or windlass repair shops in SE Louisiana so I believe I am on my own. My current solution is to put a snubber or chain retainer device on the pulpit to hold the tension and keep the anchor shank and chain from banging on the deck. But I don't want to drill another hole and put another piece of hardware on my deck.
The cost and pain of pulling the entire windlass off the boat and sending it off for repair is more than I want to incur. I also believe that I could repair a part if I could determine what was required.
Any guesses?
Buck
Any guesses?
Buck
