Hi everyone...
OK, we suspect this is a leaky window issue but I just want to double check and confirm...maybe someone else has had the same issue?
We just purchased a 1998 Sailfish 272 and are trying to work out the kinks. After a series of heavy rains, we went into the cabin and noticed the cushions were damp. After investigating, we realized it was coming from the right side on the cabin (head side). The wall felt damp and the majority of the moisture was on the right side cushions and the "bumper" cushion that runs along side the hull. The left side is dry and not showing much signs of moisture.
At first we thought it was the anchor windlasses. This boat is larger than our previous boat and parks in a boat slip under a deck. The rain runoff was falling directly on that opening. After adding some materials to the deck to detour the water, we saw the cabin was STILL getting wet. Now we are wondering if it coming through the windows....
Any other ideas of areas to check so we can troubleshoot??
Thank you!!
- A soggy Grady Lady
Thank you!!
