SPLASH!!!! :)
journeyman
Gloucester, MA
Thanks to all who advised on all my questions this winter and helped make all my projects a success!!!!!!!!!!!! :D :D :D
Washed / Waxed (2 coats) / Polished.
Bottom painted (water line adjusted and a full coat of Ablative).
Auxilliary Tank space - New plywood resin coated with access plates to bilge and scuppers to drain any unwanted water.
Rods and reels cleaned and lubricated and respooled.
Battery Charger installed with inlet on transom.
New 8' VHF antenna.
Cabin Rod Racks finished.
Made a transom mount Baitboard.
Radar installed (need to tune and learn how to use :D )
Radar on a Seaview Mount. Had to lower my GPS.
I'm TIRED! Now it's fishin time :D
Pictures re-uploaded using Imagecave.
When I created this post , everything looked and worked fine!!?? Will try again......... Edited original post- see above.
Seeing images
If I right-click and select "View image" then it opens in the same window.
If I then 'copy' and 'Back' it is in the post.
I will try here, using the box at top of reply box:
"[img]" was all that appeared and as you can see that is not enough code,
[img]http://lh4.ggpht.com/_8Aqk1wmjGCU/SfTiEG-XENI/AAAAAAAAAEw/sSUxgaOCUHc/DSC01588.JPG
What is needed is that
(no space between ]and url[).
