Stero Troubles
Gulfstream C
Anyone ever have a problem with a Kenwood stereo. It has a removable face plate, and when removed, the little red security light glows so I know it is getting power but it otherwise appears dead. No sound or other display lights come on.
DogBone
Tampa Bay
Sometimes there is a small reset button you have to hold in with a pin as you power up that will reset everything. I've had to do this on a Jensen marine stereo before that quit working. Not sure if yours has this or not. Mine was behind the face plate on the main body of the stereo.
Gulfstream C
Thanks DogBone. Mine does have a reset button which I tried pushing. On yours, did you have to hold the reset button in and then at the same time push the "power on" button. I just tried pushing reset for a few seconds, then pushing the on button.
DogBone
Tampa Bay
Yes I think I did have to hold the reset in while I powered the unit. See if you can find a manual for your stereo online, it will have the specific instructions for your unit. The reset did fix my unit that was not working.
