So I need some suggestions on how to repair this hole so a screw can get a bite.
My first thought is to use some West systems with a stiffening filler to level out the out old hole, then use a 2" wide piece of glass cloth on the bottom and top of this corner, then follow that with a 1" strip of glass cloth top and bottom. I'd trim to fit. That would give me four layers of glass for a screw to hold.
Any suggestions? The green Frog tape is to add contrast to the photo. Click to enlarge photo.
This started off as a project to drill out other stripped screw holes to 1/2" and then fill in with thickened epoxy. I have some moisture issues that I need to investigate as when I drilled I had some wet wood coming out. I'm not sure if my temporary cover failed and the rain water got in to the screw holes or if the wood is soaked. I'll have to drill a test hole to find out. These are located on the wood between the fuel tanks and the bilge hatch.
