Had motors tilted up for a few days at marina. When using the throttle lever mounted switch to lower both simultaeneously the port motor hung up a bit before eventually lowering. I need to check that the tilt lock lever didn't fall in the way but beleive it did not. Any ideas on what would cause this? Trying to find a reservoir which maintains associated fluid but nothing noted in manual.
Being a long weekend want to thoroughly check before heading out. If any thoughts on enduring proper operation please advise - new outboard owner
