What was swaying the most, the trailer or the vehicle? In cases where the tongue weight is too large, the front vehicle tires loose grip and that can lead to instability of the vehicle. If the tongue weight is too low, it will make the trailer unstable on a twin axle setup.
If the hull is too far back it can put too much load on the rear axle of the trailer. That can cause instability. I assume you have a twin axle trailer. How many and what model motor(s)?
I am curious how you measured the tongue weight,
Center of load for that hull is about 88 inches forward of the transom. Measure that distance and see where that point falls relative to the axles. Ideally, you want the center of load a bit forward of the axle to axle centerline. That is what creates the tongue force. Of course , a bracket will shift the center of load so the measurement is not perfect.
Also check that the trailer is sized correctly for the hull, not just load rating but transom to bow eye measurement. Too long a trailer can be a problem as can too short a trailer.
