Tournamant 225
imcnee
I am looking for a mid to late '90s 225 and have found a couple that have low hour Yamaha 200 two stroke engines. I have heard they are "bullet proof" but very thirsty.
Any comments would be appreciated
All true. Definitely have the engine surveyed anyway. A qualified Yamaha mechanic should also do a systems field test - will cost some dollars but well worth it.
I had a 1995 200 HP saltwater series. The last of the normally aspirated outboards. This engine had over 1,500 hours and was flawless. Yes, it sucked down the gas but it never gave me any pause and was easy to work on. Check the gaskets at the power head base for salt. This is a sign of the gasket failing.
Have it checked out and make sure the person doing the work understands how to compression test the engine. Hot and WOT vs cold with the throttle closed makes a big difference. If I remember correctly you want the numbers hot and WOT. Also, have the T-stats pulled this will tell you if the engine was flushed on a regular basis. I flushed mine after every use and had zero (0) salt deposits in the cooling passages.
Good luck.
