trailer issues
Hotajax.....boy does this sound familiar, had a similar issue. I do use the round Ford plug so a different type of connector. I've had to "bounce the empty trailer down the ramp more then once... load rite trailer. I called the dealership, the manufacturer, even asked questions of others. Some how I got in the mail detailed info on the trailer. It turns out that load rite over loads their brake system ... I have the 28T8000 bunk model infact. What I'm going to tell you has fixed my issues and I have not had locking brakes sense. Because the fluid in the braking system is under such pressure and the size of the system itself it takes a few moments for it to release the pressure so you can back up without locking. In the past I would pull up in front of ramp, drop it into reverse and my troubles started....now, its pull up in front of ramp, come to almost a complete stop, go to neutral, I may roll a little bit forward most of the time not, but Do NOT put foot on brake during this ... I do it to a count of 5, drop it into reverse and have not had any issues sense. I know it sounds crazy but the trailer I have has a 12000 lb braking system (for a 8000lb trailer)....you need to let that release the pressure before attempting to back up. If u need more info PM me.
