- Jul 15, 2024
- Age
- 66
- Woodville, Florida
- Seafarer
I bought 4 new scuppers from Amazon and they fit perfect. My only problem is that on of the flaps won't close because the inner brass tube protrudes out to much. I saw a link how to replace the tubes so I think I will try this out.new flaps on amazon https://www.amazon.com/dp/B0019M5JPY?psc=1&ref=ppx_yo2ov_dt_b_product_details
See this thread to replace the tubes
https://www.greatgrady.com/threads/transom-maintenance.37746/post-267266
Cut the old flap off and use as a gasket to extend it out. Thats what I didI bought 4 new scuppers from Amazon and they fit perfect. My only problem is that on of the flaps won't close because the inner brass tube protrudes out to much. I saw a link how to replace the tubes so I think I will try this out.
Thanks for all the information.
I tried that but it the flap still sticks out. I ended up grinding down the brass that was sticking out just a bit. The flap still sticks out a tiny bit, but If I'm not mistaken, don't the all stick out a bit? Or should they lay completely flat?Cut the old flap off and use as a gasket to extend it out. Thats what I did
Sometimes they stay open a little until water pressure closes them but they should not be pushed out by the tubeI tried that but it the flap still sticks out. I ended up grinding down the brass that was sticking out just a bit. The flap still sticks out a tiny bit, but If I'm not mistaken, don't the all stick out a bit? Or should they lay completely flat?
