Trim and tilt seals Yami SX
Tilt and trim seals, SX Yami
Last week I resealed my tilt and trim cylinders on my 18 year old 150SX motor. They started to leak at the end of last season (saw an oil sheen on the water at the dock)
Thank goodness for utube for guidance and to Sim Yamaha for parts list.
I won't go through the whole process but I will offer some tips and findings.
I purchased top quality spanner wrenches made for the cylinder caps on my motor. They were not cheap but worked very well. You need two different wrenches since the spacing and pin diameter are different on the tilt cylinder and the two trim cylinders. Use the safety stop to hold up the motor.Do nor drain the hydraulic fluid as some posts had suggested.
I did the trim cylinders first since they were easier to do and it actually made the whole job easier. I had to add a longer pipe to my breaker bar to free the cylinder cap but no hammering was needed, just a good pull.
Remove, reseal and replace one cylinder at a time. Why?? The pistons tend to stick and instead of needing a special piston shaft pulling tool, I used the tilt switch to force some fluid into the cylinder I was working on. That helped free up and move the piston. Make notes of which way the seals face. Installing the inner seal is easier (but still tricky) from the bottom side of the cap. Install the outer seal from the top side of the cap. When installing the repaired piston, using the switch again in the down mode helped pull the piston into the cylinder enough to allow the cap to seat in the threads.
Once both trim cylinders were done, it was time to do the tilt cylinder. Loosen and unscrew the cap using the proper spanner tool. Remove the circle clip from the upper pin, remove the fat pin and watch out for the plastic bushings. There are four of them.
Retract the shaft again using the tilt switch. Swing the entire trim/tilt unit away from the transom. If the piston assemble doesn't clear the motor, lift the motor higher. I was surprised how easy that was to do from the safety position.
Now remove the whole piston unit. ( there is a small gotcha which I will explain later)
Unlike the trim pistons that can be slid out of the caps, the tilt cylinder has a head that the pin goes through. To remove the piston shaft, you have to remove the lower piston. There is a big nut 15/16 inch I think.
The nut may be difficult to turn and clamping the head knuckle in a vise will be necessary.
Here is the tricky part and thanks to a post I read for this heads up.
Under the nut is a washer. Under the washer are five springs. Inside each spring is a metal plunger that has a lip that faces down looking from the underside. Underneath each plunger is a VERY SMALL BALL BEARING that acts as a check valve.
If you hold the assembly right side up or don't realize that the balls are there, you may lose them.
Once they piston parts are removed, the piston can be removed from the shaft and the seals and o-rings replaced. The process is the same as for the trim cylinders.
The gotcha I noted:After I finished the rebuild I still had one o-ring left over. What the heck!
Turns out that in the tilt cylinder there is a second piston called the free piston. It doesn't automatically come out when you pull the main piston. It took me a bit of time to figure this out but after looking at the parts diagram over and over, I went back to the boat, and while looking into the open tilt cylinder, I pressed the up switch. The fluid pushed that second 'Free' piston up and out and sure enough, it has an o-ring on it.
To reinstall the free piston and the main piston, I again used the pump in the down switch position while pressing on the piston. That pulled in the piston. I had to do the same a bit more aggressively to pull the main tilt piston in enough to catch the threads.
Reconnect the main axle pin remembering to grease and install the four bushings, pop on the c-clip and you are ready to bleed. Add fluid to the reservoir and use the up switch until the piston goes all the way or struggles to move. Add more fluid and cycle the tilt and trim all the way down and back up. Repeat as needed until the tilt works its full range and the reservoir doesn't take any more fluid. I used a plastic syringe to add the fluid.
So not counting the time taken to figure out where the last o-ring went, the job took 2-3 hours.( I slept on the issue of the extra o-ring:)) Getting the hang of installing the lower seal took time and experimentation but as mentioned, install them from the underside of the caps and use something like a dowel to push them into place to avoid damaging the rubber.
I was lucky that all three caps came off without damage and without excessive force.
Total cost? About 90 bucks for the parts kit and $150 for the two spanner wrenches. Probably less expensive then having it done at a shop and having to trailer the boat to the shop. Besides, it was a challenge and turned out well.
Hope this helps somebody.
Seasick
journeyman
Gloucester, MA
Good write-up. Thanks for sharing.
Last week I raise my motors for the first time since last fall and on one of my trim cylinders, the dust seal (not the trim seal) popped out. In order to get it back in place, I had to remove the cap. I bought the wrench at http://marinetechtools.com/. Measure the whole diameter and the "center to center" whole dimension to get the correct wrench. It comes with a spare set of pins. Easy-Peasy. As stated, having the right tool makes all the difference!
Marine Tech are the spanners I bought;very well made.
Just ordered my spanner wrenches. Thanks for the link. Both trim seals are in need of replacing so I'm sure the tilt seals are not far behind. Great write up also.
Other than removing the nut on the tilt piston, the biggest challenge is reinstalling the cap seals. At first it seems that there is no way they can be inserted, they seem too big,
As mentioned, insert from the underside of the cap making sure that the lip faces the correct way. Then push the seal from the underside into the hole and from the top side, get one section of the seal into the groove. After cursing a few times, you will get the hang of holding that section in the groove from the top using something thin ( I used the shaft of a small screwdriver, a thin dowel would work too) and pushing the other side end of the seal from the bottom using something round and flat like the butt end of a small dowel. As you apply pressure from the underside, use the screwdriver from the top to push the seal into the groove. Do not use the pointed end of the screwdriver just the smooth side. Eventually the seal will slowly slip into place and pushing the seal from the bottom will force the final section into place. A little hydraulic oil on the seal will help. Outer seals are a lot easier.
When you disassemble , lay the parts in order on the table and in the same direction and position they were installed also noting which way the cap was. You would be surprised how easy it is to forget whether the white plastic washers go on the top or bottom of the o-rings:)
Forgot to mention: I got the trim seal kits and tilt parts from Sims Yamaha. For the tilt you have to purchase separate parts. The trim seal kit has all the parts EXCEPT those white plastic slit washers. So be careful removing them since you will be reusing.
Thanks for all the tips.
Wrenches came in today and I'll try and remove the caps before I order parts incase I need new caps as well.
Got my parts at Boats.net
61A-43822-00-00 SEAL,TRIM DUST 2 $14.61 $29.22
61A-43861-00-00 O-RING 2 $5.04 $10.08
61A-43864-00-00 O-RING 2 $2.21 $4.42
61A-43874-00-00 RING,BACK UP 2 $7.52 $15.04
61A-4389H-00-00 O-RING 1 $2.60 $2.60
6H1-43861-00-00 O-RING 1 1 $4.83 $4.83
6H1-43861-10-00 O-RING 2 $5.04 $10.08
6H1-43871-10-00 RING, BACK UP 1 $8.96 $8.96
6H1-43872-10-00 RING, BACK UP 1 $4.07 $4.07
6T4-43875-00-00 RING,SNAP 2 $2.14 $4.28
(One of these o-ring numbers might be for Lower Unit gear oil seal housing...)
journeyman
Gloucester, MA
At first, I used a breaker bar and found that the wrench tends to rise out of the holes. Careful, the holes can be damaged! I switched to a ratchet and was able to twist the wrench in a position that when place on the cap, gave me some leverage to help keep the wrench in place. Kind of hard to put into words.......
I also use a ratchet but with a pipe added to the handle for leverage. The spanners mentioned have three pins and it is important to make sure all three are firmly seated. In other words keep the spanner flush to the cap.
I just had to apply force but no whacking to loosen the caps. As I mentioned, remove one cap at a time so you can use the hydraulic pressure if needed to push the piston out
Got the trim caps off. Port side came off fairly easy, tight but still turned. Now the starboard side was a different story. Broke off 2 sets of the pins, didn't want to break more, need them for install. Took a chisel and hammer to the cap, took some convincing but it finally gave way. Haven't done tilt yet, may wait till after my Florida trip. Ordering parts on Monday for the trim.
Nice write=up, Seasick. Thanks for taking the time to post it.
Just adding a tip I learned along the way (that I filed into my "mental" toolbox)...
A piece of PVC pipe slipped over the trim ram such that you can trim the motor down onto the top of the pipe, and the bottom of the pipe sits on top of the spanner wrench, helps to ensure the wrench stays flush/level with cap. A pipe cut to fit around the tilt ram and the upper hinge eye can work for the tilt ram. I haven't had a need to do this yet on my motor, but it seems like a great idea to help keep from stripping the cap. Once you get it started, tilt the motor back up onto the rest.
That's a neat trick for the trim. I suppose that by cutting a slot in a PVC pipe, one could use the same trick for the tilt cap.
artodea
Boston Northshore
Back in my Yamaha days I had the trim cap removal tool from Sim that used set screws for the pins and they used to snap all the time. I replaced the set screws with dowel pins (sorry, can't remember the size) after drilling out the threads with a drill bit matched to the dowel pins. I could apply a whole lot more torque before the pins snapped
***edit***
Just looked it up and found a picture: Dowel pins were McMaster Carr part no. 91595A184 and the 4mm drill is part no. 30565A261
***edit***
Thank you, I'll keep that in mind. Don't guess you need to do trim/tilt service with the G2.
So far, so good, re-installed the trim caps this morning, will bleed the system this evening when I get home if the rain holds off. I bought all the caps and seals/o-rings for both trim and tilt. I'll watch the tilt, but will probably do it after Florida, it's leaking, but not near as bad as the trim was.
Ozz043
What an interesting thread ! :dance
Cheers SEASICK !
I have already rebuilt trim seals on stbd 250hp OX66, thinking I might do the whole lot after reading this thread as the port tilt seal is weeping slightly. I found the trim fairly easily though a hammer and screwdriver was required to remove the cap..
I will purchase the tool posted previously but that only does trim not tilt caps...
Where can I find the tool for the tilt caps ? What do you think about these ?
https://www.ebay.com.au/itm/NIB-Yamaha- ... 1412284459
https://www.simyamaha.com/Yamaha_Trim_a ... ytrim3.htm
I can only comment about the MarineTech tools. There are three possible tools for the different Yami motor. You need a different one for trim and tilt caps ( that is two tools for a specific motor model). Their site will list the motor models and type(tilt or trim) that each tool fits
