trim gage stuck on three ?
fishone
Connecticut
I have a 1995 seafarer, during my shakedown run I noticed that my power tilt gage is stuck, however the trim works fine? I am not an electrical guy and I'm wondering what I should check first? any help would be great.. Thanks
Bumpye
North Shore, Massachusetts
Had the same problem last year on my 03 Gulfstream. The shop replaced the sending unit (about $250 w/labor). Works great now. Made a huge difference in trimming out for best RPM and speed.
Finest Kind
Hallandale, Fl
Dunno about your motors, but on my ETEC's, there is a sensor under the motors (visible when you trim the motors all the way up out of the water), that looks like a little black lever connected to a circular flat spring. This trim level sensor sometimes sticks and needs a good squirt of WD40, some grease and some massaging to get it working again...
Try that before you go back to the Stealership for expensive repairs.
SmokyMtnGrady
The sending unit is a mechanical potentiometer and often it just needs to lubricated. Mine sticks from time to time and I just squirt a dash of Teflon spray in there .
