One piston startsFirst thing to try is checking the oil level in the tilt reservoir just to eliminate that.
After checking tilt up the motor until you can activate the tilt stop (lever that keeps motor from tilting down). Now tilt down (activate the switch) and see of the rods retract. If not, try lightly tapping the ends of the rods to see if they move.
I suspect that your system may need trim fluid or need the fluid replaced with clean fluid.
It could be other things of course but do the above first
when the locks are activated (motor trimmed all the way up) both pistons go down but when the motor goes down one of pistons won’t go down.First thing to try is checking the oil level in the tilt reservoir just to eliminate that.
I’m gonna get some fluid today and try that, hopefully it will help the problem.If the tilt system is low on fluid, air pockets will form. Just cycling the motor up and down can bleed the bubbles out but there has to be fluid in the reservoir to bleed completely
You might also have contamination in the oil that is causing a check valve in the pump body to not "check" and result in low hydraulic pressure
