.. but trim tabs do change the running angle of the boat.
I assume you're speaking to me since fgunner only asked a question. Not splitting hairs or slinging crap, only speaking of the physics involved. Yes, tabs do change running angle. When retracted they obviously do nothing. But when they extend the running angle goes moves bow down, wetted surface expands (side spray moves forward), drag increases, and any fuel mileage changes will be negative. Any reversal of those attributes will only occur when tabs are retracted from an already extended position with the above degradations already in effect.  At least that's the way my boat acts with Bennetts.  My fuel economy is best with the motor trimmed out just short of the porpoise point and the tabs retracted. The only tab movement possible is extension, with the aforementioned characteristics.      :?
So to answer your question, fgunner, tabs on a 225 aren't required, but they will allow you to easily level the boat when running, and will smooth out a choppy ride to a certain extent.  I bit the bullet (EBay is a wonderful place) last year and don't know why I waited so long ...        :wink: [/i]
