I'm going to do a little trolling this year and would rather avoid putting a kicker on my Tournament 19 with a 2 stroke 155hp commercial Evinrude. Would like some pro/con comments on using a trolling plate.
Skip the trolling plate, especially for saltwater (the screw holes will corrode in the anticav plate). I would recommend instead some trolling bags which you can purchase from the following site: http://www.amishoutfitters.com/catalog2.htmLeigh said:I'm going to do a little trolling this year and would rather avoid putting a kicker on my Tournament 19 with a 2 stroke 155hp commercial Evinrude. Would like some pro/con comments on using a trolling plate.
I've got 100s of trolling hours on my 150s. Just ensure you decarbon every 50-100 hours.SCAdventure said:I was under the impression trolling with a 2-stroke was not a good idea. Am I misinformed? The Grady I just bought (1995 208 Adventure with Yamaha 225 2 stroke) has a 9.9 hp 4-stroke kicker.
My trim tabs all the way down, and motor up as far as I care to raise it (while running) only accounts for about 3/10s of a knot reduction in speed. If you put a rope on the back of the bags, tied off to the rear cleats, you can pull the bags up with little effort. The rope back there also keeps the bags from moving out from or under the boat.sfc2113 said:Someone told me I could use my trim tabs to help control trolling speed,
by putting them all the way down. Not if this is true as I hsve not put them on yet. We tried the bags last year worked out ok but, was a bit of work, had to get them in when we hooked up because the fish would sometime goto one side and we would end up getting tangled up with the bags. Not fun with 2 people.
Workdog said:I've got 100s of trolling hours on my 150s. Just ensure you decarbon every 50-100 hours.SCAdventure said:I was under the impression trolling with a 2-stroke was not a good idea. Am I misinformed? The Grady I just bought (1995 208 Adventure with Yamaha 225 2 stroke) has a 9.9 hp 4-stroke kicker.
Hope it all works out for you.Leigh said:Workdog,
Just got off the phone with Frank at Amishoutfitters. Based on his recomendation I ordered 2 22 inch Beefy Bags. Very nice and helpful gentleman. Thanks for your input
