After posting problems with this pump this Spring, I ordered a rebuild kit and replaced items in the kit on this unit.
Pump worked fine for the livewell, however the washdown had a lot less pressure that I had expected.
This past weekend the livewell stopped overflowing on the port side outlet. I have yet to take out the cabinets that are in front of the pump but I can hear the pump motor running just not pumping any water.
This pump in a bad place to have to be removing it multiple times a year.
Is the Jabsco pump the best pump for this application, or could a newer pump of some type be of a benefit?
I just want to fix this one more time if possible.
Thanks for your help.
