Having a issue with my livewell pump.
Took the cabinet apart last night and found a cracked line on the output side of the pump. Most of the water being pumped was running into the bottom of the boat.
Fixed the line from the pump and it pumped fine into the baitwell.
Tonight I filled the freshwater tank and was giving it a little flush, and the breaker to the pump kicked. Reset breaker and about 2 minutes of pumping water from the tank it kicked the breaker again.
Pumps and motors, belts all looked fine.
I did notice that if I put my finger over the dishcharge line when it was pumping it really slowed the sound of the pump down, I would think that would be normal.
So this weekend I will take it apart again, just wondering if anyone has had similar issues?
