Under Gunnel Rod Holder Straps
Adding this in the Tips section for anyone that needs to repair these.
The stock under gunnel rod holder straps use standard hardware that you can get from a kayak dealer. The top screw end and the bottom J hook end are offered and are basically compression fittings. I didn't find the rubber bungee material, but on my boat the J end broke. I simply worked the top compression fitting off and removed the J hook base. I ordered a few from this place and plan to re-use the existing rubber bungee material. You could replace the bungee with any standard 1/4" bungee material offered if desired.
Here are the links:
For the bungee cord: http://www.kayak-solutions.com/bungee-c ... d_search=0
For the J hook end: http://www.kayak-solutions.com/bungee-c ... d_search=0
For the termination end: http://www.kayak-solutions.com/bungee-c ... d_search=0
