Value of 1987 24' w/ bad engine
Swedesboro, NJ
A friend is interested in buying an Offshore '87 with an I/O engine that needs replacing..the boat (hull, outdrive, etc,)is supposed to be in good shape with decent electronics and no trailer. I know putting a value on this will really depend upon the condition, but what would be an approximate value and cost to rebuild or replace the engine. It's priced at $4K. Thank you!
gwwannabe
Piankatank River, Gloucester, VA
This is just my opinion so take it for what it's worth. I wouldn't pay that price unless it had current electronics - radio, gps, depth finder at the least, a full set of curtains, and a set of cushions in decent shape. This is after passing a good hull survey by someone experienced with Grady's.
You didn't say what engine is in the boat but presumably it can be replaced for under 8,000 with a shop doing the work. You could probably do it yourself for around half that. Not sure what a rebuild would cost but would probably not do that myself.
Based on the postings I've read here over the last several years, it's usually a lot more expensive than expected to refurbish. I'd probably plan on 20k by the time he gets a trailer and gets it the way he wants it. Again, just my opinion.
Gary 89 Overnighter
finnaddict
moriches
just checked nada and the hull is valued around 4500 to 5000. If I was your friend I would have it checked out and definitely figure how much He is willing to put into it.By the time Hes done a few hundred either way for the hull is not going to matter in the grand scheme of it.
