Vent Window
Rob_PR
I'm looking for the starboard side Vent Window with Frame for a 1992 Marlin. Looking for actual window.
Legend
Southern New England
My Sailfish the port and starboard are identical. Guessing the Marklin is the same. You can take the port window to a glass shop and they can make a template and then have it sent our to a supplier and have it made to of tempered glass. Some people opt for plexiglass. I had one done a few years ago - cost around 100 bucks
SeaVee
If you’re missing the black metal frame part as well as the glass it makes it a little trickier, the metal piece ( I think it’s called an extrusion) is hard to find. I ended up getting mine from Marine Glass Specialties in FL. He has the OEM GW extrusions. He probably has done a Sailfish before and might not need a template. Not cheap, but I wanted it to look original.
They’re hard to get a hold of so have patience. I dealt with George originally , but he was out a few months back so I dealt with Tex.
Rob_PR
Rob_PR
Thank you will check this option out.
Rob_PR
Rob_PR
Thank you. Yes, I'm missing the black metal frame part as well as the glass. I'll check with Tex. I think George passed away.
