VHF Anetnna
HalcyonDays
Freedom 307
I snapped the top 6" off my VHF antenna going under a bridge, so I had my local Grady White dealer install a new one. I was thinking they would pull the new antenna wire back to the radio. How they installed the new antenna was to cut the old antenna cable where it comes through the hard top and then they spliced the new wire to the old wire there. Is this the correct way to install a new VHF antenna?
Billv
Schooner Island, Wildwood NJ
Done properly and professionally a VHF antenna can be spliced. I can’t really tell from the picture if this was done well or not.
IMO any splice should be under the hardtop or at least weatherproofed. There are antennas available now that "plug in" inside the ferrule making an exposed splice unnecessary
If the splice was mechanical with a special coupler and the assembly is waterproof, it should be OK. If instead they peeled back the center core and braid and soldered the wires to the old wires, I would not accept that approach.
What is that connection covered with?
Ekea
Mid Atlantic
with the poor quality of the picture, we are just guessing here...
