Washdown valve
X SEA O
My wash down, livewell valve cable broke on my 93 Gulfstream . Where can I find a replacement?
Fowl Hooked
Southern Maryland
Not familiar with the cable arrangement. My 265 has extension rods for the seacock valves and the ball joint connector that joined the rod to the valve handle rusted out and I replaced those. Are you looking for that sort of thing or it something completely different?
X SEA O
My valve has a push pull knob that attaches to the selector valve via a cable that is broken
X SEA O
Thanks anyway for the reply
Fowl Hooked
Southern Maryland
Not sure if it would work but if you can access it at both ends maybe you can just replace it with some stainless steel cable cut to length from a hardware or marine supply store?
