WATER HOOK UP FOR BOATS ON A LIFT?
casey6901
Key West, FL
All,
We recently purchased a floating boat lift for our 305 Express. Is there any way to hook up water to the intake so that we can run our AC at the dock while the boat is up?
Thanks in advance for the advice!
Chris
gw204
St. Leonard, MD
You could probably T into the intake hose downstream of the seacock. Just make sure you close the seacock when you want to run from the docks water source.
Also, make sure your water source has enough volume and pressure to supply the AC.
Bebo
My Sailfish has this as a T with a separate valve to close it off. I have a hose hookup too, that is built in near the fresh water fill. This makes it easy to flush as well.
