Water pressure pump
Joe arrigo
New Jersey
I don’t here anything when I switch the water pump on to run my faucets water tank is full want to drain it but getting no fresh water
Not being wise...
Is the breaker for the water turned on?
Joe arrigo
New Jersey
I took my water heater out and blocked off the lines . I don’t think that has anything to do with water pump not working and were is pump located
Legend
Southern New England
Sounds like the pump may be shot. Did you check the power from the wire at the pump ?
if you are not popping a breaker, the voltage check should be easy to do. I'm guessing the pump as well as it is a fairly simple system. Water heater should have no impact if bypassed.
