water pressure switch
Rtroska
Freedom 307
I have a 2011 Freedom 307. When I flip the water pressure switch on the panel I used to hear the pump start. Now I hear nothing and no water pressure and no water out of the house, sink or whoer. Any suggestions...could it be a fuse? Pump?
Sure, it could be either of those things. Could also be a clogged filter or faucets/aerators. Could be bad/dirty/broken wires/connectors at switch/pump/anywhere in between. Start with the easy things.
Legend
Southern New England
Some boats have a push on off at the faucet faucet nozzle. I have had people shut the water off there and when you turn the water on you get nothing. Long shot but give it a check.
Water in tank?
Tank clogged? If you have't used the fresh water in a long time the tank can be a mess. A hard spray from the hose into tank can get stuff moving...then a full cleanout.
Otherwise, yes, check fuse and inline filter if ther is one. Does switch light?
