HOWEVER... the fix should be a simple "Mr. Dealer, please fix this".
Wait a minute... looking at the pic again... swap the feet side for side. See if that works. I think they're just on the wrong side.
You're right - it's welded. I didn't notice that. I still think the problem is they're on backwards, though. Unfortunately, it seems they were installed and THEN the hoop was welded to them. So... back to "Hello, Mr. Dealer"I don't think you can swap the feet. It looks like they are welded to the arch bar that goes over the top of them. I can't tell from the picture, but If you rotate those feet as suggested, perhaps the whole anchor will tilt back and snug up to the roller. Ideally, you want the anchor pulled tight to the roller w/o the tip hitting the hull. I also questioned if the anchor it too big?
