It's that time of year here in the Northeast where one needs to start thinking about winter storage-- and that also includes winterizing our engines. I never winterized my engine before (yard did it), but this year I decided to try it myself! I have many questions, and I hope the group will forgive my ignorance!
First: My enigne is a 1997 Johnson 175 v6 oceanrunner.
I figure to first run the engine up to temp at low idle with a garden hose to flush. I have a pair of earmuff style flush attachment, but water only goes in on one side of the ear muff. I wondered if this is ok to use or do I need an earmuff that feeds water from both sides?
Now, after running for 10- 15 minutes to flush, would I then switch to an antifreeze mixture? Is this necessary, and when should I begin to fog out the engine? I don't want to run out of antifreeze before the engine stalls out.
Next my biggest question is how do I attach the special oil, stabilizer, and gas soup that I will mix in my small 6 gallon tank to the fuel hose from the engine? I figure to attach directly to the tank, but what about the VRO oil line? I have heard that if I disconnect that line I can burn out the three chambered pump that mixes the oil and gas. This is where I could use some help!! Do I continue to draw oil from the VRO and not mix oil in my gas and stablilzer in the 6 gallon tank, or is there another way to do this by cutting off the VRO oil supply and mixing the oil in the 6 gallon tank? Do I run the engine until it stalls out from lack of fuel, or turn it off before that?
Thanks for any help here-- as you can see I'm pretty confused!!
Gradyrod
1985 Fisherman 204
Gradyrod
1985 Fisherman 204
