- Wire Tracing for a 330 Hard Top
Chutch
Merit Island
I'm chasing down a bad - ground wire from my hard top. Any ideas what -busbar it runs to from the Hard Top? I pulled the electrical panel and cleaned the - busbar behind the panel no joy. Is there a ground connection on the Accessories fuse panel? (hard to see where they put that thing) if I jump from the VHF ground everything works so i know its a bad ground to the fuse panel in the hard top. Thanks
On my 2007 330 I have two auxiliary fuse panels, one is behind the center area of the overhead electronics box feeding the anchor light and VHF radio. The other is up higher behind the cabin electrical panel almost behind where my auto pilot controller is installed. The panel is visible after removing the cabin electrical panel and looking up and to the port side.
Reactions: mg1826 and Chutch
There is a connection plug on the starboard side around where the fuel fillers are under the gunnel. Not the easiest to access.
Let me know if you need any more assistance finding it!
spot on. found the offending corroded plug behind the bolster and round access.
Reactions: kirk a and mg1826
