I have a 150HP 2 stroke motor on 1994 Grady White. had the carbs cleaned out and ran it 6 times on Cape Cod few weeks ago and and it ran flawlessly. I brought it back to NY two weeks later and started it in my driveway with earmuffs on and I noticed no cooling pee stream and the alarm then sounded.
I turned the motor off and let it cool down, I then submerged the lower unit of engine in a 40 gallon container without earmuffs and tried it again, at first no pee stream then a weak one, followed by the alarm once more. I turned t
he engine off again. I brought the boat to a Yamaha dealer, they replaced the water pump and tired it again the same result however- the alarm once again sounded with a weak pee stream.
The boat is still in the shop, they plan on removing the engine heads, they think there is blockage on the right side of the engine. Is this the next logical step? The thought is that there is blockage as a result of salt water scale and salt build-up. I noticed that there is a triagle above what I think is the oil gauge- it's the round circle that's almost entirely black? Could the alarm not be a result of overheating but rather with the oil delivery system? Both the aux. and main oil resevoirs are full, I did notice that after the carbs got cleaned that the boat seemed to use less oil- not sure if this is a cooincidence or not? Any help would be appreciated....
