Yamaha 150trs-175trs-200trs-200txrs - What is this hose for?
wspitler
Inglis, FL
Pitot pressure to provide water pressure to speed sensor on a Yamaha gauge. Not real valuable given today's GPS connections and GPS speed availability. Highly prone to clogging as the port on the leading edge of the outdrive is quite small.
Reactions: PolarExpress
PolarExpress
@wspitler Thanks! I noticed it was disconnected the other day, popped it back in, and it came out again. Doesn't seem like something I need to replace based on the usefulness of GPS.
Not critical but you don't want it spitting sea water inside the cowling, If it pops off, I would bet it also is spitting water.
PolarExpress
@seasick - that's a good point. In my case, might not be a problem, as the disconnect happens at the base near #9 in the diagram. However, will be something to check and address!
