Yamaha CL7
John Killian
Anyone have (and solved) a problem with the fuel tank monitoring system? I have a 2021 Freedom 235 and after launching this year, the fuel tank monitoring system no longer shows any data. The first 2 years have been flawless and this is the only issue I noticed when checking all systems at launch today. On a related note, can I assume the fuel consumption data is not related and I can use it to measure fuel usage until I can solve the tank monitoring.
Thanks in advance.
John Killian
Sauza45
Sarasota
I use the fuel consumption data all the time. It tells you how much fuel you used, I have 189 gal tank, if the data says I used 80 gals I have 109 gal left. The data is very accurate. When I go to
the gas pump If it says I used 125 gal thats all I can put in .
John Killian
Perfect, thanks.
