Yamaha Speed reading not correct
Hi,
My speed indiator on the yamaha gauges isn't giving the right speed. I think there may be some debris causing it not to work. Can anyone tell me where to start looking? Thanks for your help!
Fishtales,
If it's like my F250 TXR there is a speed pick up hole on the leading edge of the lower unit down low. It is easy to pick up some debris etc in there especially if you run over a stick or something else. If you see it is clogged take a very small drill bit and maunually screw it into the material by hand. You can then pull the drill bit out along with the obstruction. Hope this helps and good luck!
Fishtales said:
Hi,
blow from the gauge back towards motor
Forget fixing the Yammie speedo and just go by your GPS!
Unless of course it starts messing other things up too.
