The plastic end of the Yamaha wire bundle is quite large in size, and it will not fit in the entrance to either rigging tube. The inboard most tube has a wire bundle wrapped in black corrugated sheath going from the battery to the helm, and the outboard most tube has the hydraulic steering tubes, along with a few smaller wires. There isn’t a chance in hades of getting that Yamaha connector fitting in, even with foreplay. I also haven’t fed the shift and throttle cables in yet. These were all gutted out when I bought the boat.
Anyone run into this before? Do I have cut and splice the engine to helm wire bundle? I would hate to do that. Ticks me off Grady ran only two 3” tubes. They should have been 4”, or more of them.
I’m considering pulling the helm to battery wire bundle and seeing if I can get them back down through the outer tube, (which would free up the inboard tube) but that means disconnecting a lot of wires at either end. It’s 26 degrees here and that would not be fun. Ideas?
