Hi everyone,
I have a leak in my new-to-me Sailfish ('95 272), and am wondering if anyone might have some insight or advice.
As you can see in the photos below, water is collecting along the sides of the cabin, just below the rod holders. However, the carpeted ceiling just above those spots is dry. So, it's not dripping down from above. The wet spots are also not directly below any of the windows.
The photos also show wet streaks running down the side wall, from up behind the rod holders, where there is a gap in the carpet ceiling that leads up to the gunwhale (where the bow rail and 'bumper' rub rail both screw into the hull). I can put my hand up there, but I'm not finding any obvious leaks or loose screws, etc.
It's happening on both sides of the cabin. My best guess is that water is leaking through the screw holes of the bow rail or rub rail, and is dripping behind the carpet on the wall, and collecting at the bottom?
I will see if I can upload a video to explain things better. Thanks for any advice!
p.s. Update many weeks later: it turned out to be a leaking rub-rail. So, if anyone else ever sees leaks like those in the photos below, you might check there. See the rest of the thread for details.
