05 Marlin with steering issue
Shannon C.
Santa Cruz CA
Hi all, it’s great to be back, I’m having a little issue with steering at low speed. There is a little play in the wheel and a difficult to turn.
Do I need to add more fluid?
Does is sound like the pump at the helm is going?
Is the a additional pump that can be installed downstream?
should be able to turn with 1 finger right!
Thanks,
Could be low fluid/air pocket. That would imply there is a leak somewhere.
Could be Helm...dirty/rusty shuttle valve.
Could be that a motor, or both, have steering pivot bound up with dry grease.
You can add power assist pump to steering.
You have an upper station? That adds complexity...
blindmullet
Florida
To many variables with limited info. Pull the bleeding instructions off their site and work through it. If you can grab another set of hands it works much better.
Check the fuses near the battery as well. Quick check to eliminate this. GW uses 2 30a fuses in water proof holders near the battery. There are 2 40a fuses in the SeastR unit itself.
Shannon C.
Santa Cruz CA
Thanks guys for the input, all fixed, bled the air out and added fluid.
Shannon C.
Santa Cruz CA
I’m interested in this power assist pump, do you have one installed? If so, is there a big difference? Thanks!
